1995 Pontiac Firebird coolant boils over when car is turned
1995 PONTIAC FIREBIRD
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
MUHLEBOY
when car is turned off radiator boils over.temp is 230 when fan comes on and 220 when fan goes off,then if you turn engine off cooling system girgles and over flows out radiator overflow.any ideas. engine is a 3.4l
Jul 17, 2009 at 1:12 AM
  • CERTIFIED EXPERT
  • 110,176 POSTS
When the engine is off, the coolant stops circulating and sits in the engine which will cause this. If it is running at 230 degrees F, that is too high. Have you tried replacing the thermostat or flushing the cooling system?
Sep 9, 2009 at 1:27 PM
