1997 Pontiac Firebird changing distributor cap
110,000 MILES • V8 • 2WD • AUTOMATIC
BOOHEJM
I have the water pump off and the front of the engine stripped but I can't figure out how to get to the small star bolt behind the main belt pulley. So the question is how do I change the distributor cap on this vehicle. Do I have to remove the pulley which I tried or is there a small star female driver that will go through one of the small holes in the pulley. If there is I can't seem to locate one.
Thanks
Jul 9, 2008 at 3:19 AM
FIREBIRDMAN1187
  • 18 POSTS
[quote:48c56414bf="boohejm"]Electrical problem
1997 Pontiac Firebird V8 Two Wheel Drive Automatic 110000 miles
Yes you have to take the harmonic balencer off to change the cap and rotor
Thanks[/quote:48c56414bf]
Feb 2, 2010 at 8:21 AM
