1988 Pontiac Firebird 88 firebird ignition problem
DDMFFOOD
  • 8 POSTS
Engine Performance problem
1988 Pontiac Firebird V8 Two Wheel Drive Automatic
Still working on 88 firebird converted to carb from TPI.
Current problem is spark. Have gone thru 4 ignition modules, When new module installed, runs like a champ for a little while then begins missing. When spark coming out of distributor is checked, has great spark on one side of engine, poor spark on the other. Distributor, cap, plugs and wires all brand new.
Aug 26, 2009 at 10:25 AM
RACEFAN966
  • 5,029 POSTS
Ok when you did the change over what distributor did you use?
Aug 27, 2009 at 3:31 AM
DDMFFOOD
  • 8 POSTS
it was swapped by the previous owner im not sure what brand of distributor but i know its an hei ignition if that helps clarify at all...?
Aug 27, 2009 at 9:09 AM
RACEFAN966
  • 5,029 POSTS
OK so the distributor cap has the coil in the top of it? When you replaced the cap you did put the center button in first then the rubber washer and then the coil on top? The coil did have the ground strap? Here is a pic of what I am talking about as far as the ground strap.
https://images.2carpros.com/forum/automotive_pictures/249564_493192_1.jpg
If yours is missing then you local parts store should have it Napa #RR204
Aug 28, 2009 at 2:59 AM
DDMFFOOD
  • 8 POSTS
yes it has the in cap coil , and yes i put the rubberish carbon button then the coil on and it does have the ground strap . the car ran decently well for 2-3 weeks then started acting up giving weak spark to only the drivers side of the engine replaced the module 4 times every time gave the same result ran good for bout 20 minutes then started giving the weak spark to the drivers side again.....
Aug 28, 2009 at 6:58 AM
RACEFAN966
  • 5,029 POSTS
Ok so tell me was the distributor new or used? It may be that the condensor needs to be replaced.
Aug 29, 2009 at 2:18 AM
DDMFFOOD
  • 8 POSTS
the reciepts i have from the previous owner say that it was purchased in 2005 the car hadnt ran since 2005 also then i got it to run very good about a month ago then this problem occured so it seems to me as tho it is fairly new and pulling it out and looking at backs up my theory
Aug 29, 2009 at 6:33 AM
RACEFAN966
  • 5,029 POSTS
Ok so have you checked the capacitor? Here is a pic of it and it costs about 12 dollars. If this malfunctions it can cause this kind of problem.
https://images.2carpros.com/forum/automotive_pictures/249564_501742_1.jpg
Aug 31, 2009 at 4:06 AM
