1996 Pontiac Firebird Distributor Assembly
103,000 MILES • V8 • 2WD • MANUAL
BETTYSUE92
My son has a 1996 Firebird Formula with an LT1 350 with a manual 6 speed. The car just stopped running & we got it to a repair shop. The Distributor Assembly was replaced. We were told that moisture got into some vacum lines & ruined the distributor & that if it gets wet again, the samething could happen again. Meaning that it probably shouldn't be driven in the rain. The tech said that for a couple of years that GM made this distributor assembly that has this moisture problem. This is the cars third distributor assembly. Is there something that can be done to keep the moisture out of it? Is there any after market product that doesn't have this problem?
Not being able to drive it in the rain is not good. It was very expensive to replace. help, I don't want to have to sell his car.
Jul 10, 2010 at 12:54 PM
INTERNETMECHANIC
  • 700 POSTS
Talk to a national brand autostore, they should have something. I don't have a brand name product in front of me. I have seen people use wd40 as a moisture displacement, removed the dist. cap, sprayed everything. I don't know how flammable wd40 might be, there might be something better out there? Thanks for the donation.
Jul 11, 2010 at 6:20 AM
BETTYSUE92
"Talk to a national brand autostore, they should have something." That's it? I know that I'm a girl but I expected better even if the answer took another day or 2. Not the answer I thought I'd get. Even a "I don't know but I'll do some more checking" would have been a better answer.
Jul 11, 2010 at 3:52 PM
INTERNETMECHANIC
  • 700 POSTS
Just trying to help, have a good day.
Jul 12, 2010 at 2:03 AM
2CARPRO JACK
  • 11,533 POSTS
If an A/C Delco distributor assembly (cap and rotor as well) were used it should be fine to drive in the rain.The factory parts are o'ringed to keep water out as well as having remote vents (rubber hose) to keep it from building up pressure from the static electricity.Has the water pump been replaced? I have seen the pump leak causing coolant to get into the distributor causing failure.This isnt the best design out there, but it can be driven in the rain
Jul 12, 2010 at 5:08 AM
