It sounds like you've got something draining your car battery even when it's turned off.
Basically, you need to measure the current between the battery and ground to see how much current the car is drawing while it's off. If it's more than 50mA, you have a problem. Pull fuses until you figure out which component is causing the drain.
SPONSORED LINKS
Monday, January 26th, 2009 AT 5:47 PM
