1996 Pontiac Bonneville
BIGJOETWO2
  • 1996 PONTIAC BONNEVILLE
  • 6 CYL
  • 113,232 MILES
1996 bonneville will not start has gas fire on plugs. Long term fulel -5.5% ignition timing adv -7.0 po300 code
Wednesday, September 17th, 2008 AT 7:25 PM
2CARPRO JACK
  • 11,533 POSTS
Does it have injector pulse? I have seen some of those Pontiacs with the 3.8 rot out the upper intake manifold around the EGR and fill the intake with coolant causing no-start conditions and random misfires, is coolant mysteriously diappearing?
Wednesday, September 17th, 2008 AT 7:56 PM
BIGJOETWO2
Yes but not in the oil put on new water pump
Friday, September 19th, 2008 AT 5:59 PM
2CARPRO JACK
  • 11,533 POSTS
The leak I am refering to doesnt put coolant into the oil, it goes into thec ylinders and wets the plugs causing misfires and no-starts. Have you checkced for fuel pressure? GM pumps are great for only lasting about 100k
Saturday, September 20th, 2008 AT 7:30 AM
