1996 Pontiac Bonneville crank won, t start
PJGRIP
  • 1996 PONTIAC BONNEVILLE
  • 6 CYL
  • 147,000 MILES
Car will crank but not turn over, tested all 3 coils they are ok control module passed testing, getting fuel and spark. Help?
Friday, April 9th, 2010 AT 5:10 PM
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems
with compression and valves opening and closing at the wrong time/broken or jumped timing
belt/chain
Friday, April 9th, 2010 AT 5:23 PM
