1999 Plymouth Voyager Vehicle Won't Start (Sometimes)
OKCMANN
  • 1999 PLYMOUTH VOYAGER
Electrical problem
1999 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
My wife's van will not start sometimes, with only a click (power to everything) when the key is turned sometimes. But it will eventually start, after turning the key on and off again, several times. I replaced the batter & the ground wire, that was old. Any ideas what it could be?
Friday, May 2nd, 2008 AT 11:11 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Most likely it is the starter. If you can do the work take it off and take it to your local parts store. Most can Bench Test. If that is not the problem you will then look into the Ignition Switch.... it looks like this and is mounted on the Steering Column.....
https://www.2carpros.com/forum/automotive_pictures/188069_99voyagerignitionswitch_1.jpg
Monday, May 12th, 2008 AT 8:11 PM
