1999 Plymouth Voyager Two Wheel Drive Automatic 63K miles
I have a 99 Voyager Minivan. We recently began to have an issue with it starting at times and at other times it will not start. When this happens, you just hear a click. The instrument panel seems to display odd characters as well. Usually, after turning it off and back on (may take several attempts), it finally turns over. We took it to a mechanic that checked the starter to verify it wasn't bad. He then said it could be a couple of things. Either the ignition switch needs to be replaced or possibly the computer. He wasn't getting an error from the computer but stated that it may still be failing. I just need to know what the best guess is as to what is causing this. I don't want to spend money on replacing the ignition switch if that isn't going to solve the issue.
Aug 10, 2010 at 6:13 AM
