1998 Plymouth Voyager wont start
BRADSBABY
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 130,000 MILES
My car over heated. Now will not start. Have never had any problems out of it other then heat only works when van in movement. Oil n water looks good.
Friday, November 27th, 2009 AT 1:17 PM
My car over heated. Now will not start.-Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Saturday, November 28th, 2009 AT 3:14 AM
