1998 Plymouth Voyager Wont Start
NORMA_NANCE2004
  • 1998 PLYMOUTH VOYAGER
Electrical problem
1998 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
we changed the oil pump, because it was over heating and shuting down after running about 20 minutes, well they told us it was the oil pump, so we got that changed, and now it wont start at all. It is getting fire, but wont start even when we spray eather into the throttle body. Any suggestions?
Monday, March 1st, 2010 AT 11:10 AM
JDL
  • 16,098 POSTS
Hi, do you have good spark at all the plugs, engine cranking? What is litre size of engine? Use a gage and check fuel pressure. Around here, some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. You call and ask.
Monday, March 1st, 2010 AT 11:30 AM
NORMA_NANCE2004
. Yes we have a good spark on all plugs, and the fuel pressure is where it suppose to be. When we took the hose off the throttle body, there was oil in it.
Monday, March 1st, 2010 AT 11:39 AM
NORMA_NANCE2004
Yes we have a good spark on all plugs, and the fuel pressure is where it suppose to be. When we took the hose off the throttle body, there was oil in it. The engine is 3.0
Monday, March 1st, 2010 AT 11:49 AM
JDL
  • 16,098 POSTS
Do you have good compression on all cylinders?
Monday, March 1st, 2010 AT 3:20 PM
