1998 Plymouth Voyager Starting
REJ8445
  • 1998 PLYMOUTH VOYAGER
Electrical problem
1998 Plymouth Voyager 6 cyl Wheel Drive Type unknown Automatic 180, 00 miles
I am having problems with my van not starting - it will start two to three times and then won't start again for a day or more - we've had the starter replaced, battery replaced among other things - also have had it run through the diagnostics and they find nothing showing up - any ideas?
thanks
Thursday, February 7th, 2008 AT 11:39 AM
When it refuses to start -1st check for spark by disconnecting a sparkplug wire and grounding it to the engine and having a helper crank engine over while you look for spark-Do you have spark? -If so spray carb cleaner into the throttle body and attempt to start -did it fire up and then stalls out. If so you have a fuel system problem.
Friday, February 8th, 2008 AT 1:54 AM
