1998 Plymouth Voyager don't want to start
MEMITO66
  • 1998 PLYMOUTH VOYAGER
  • 4 CYL
  • FWD
  • 141,952 MILES
Hi I changed the computer for my plymouth voyager and dosen't want to start, suposed they're sending to me already programed
Thursday, March 11th, 2010 AT 5:30 PM
Do below to determine if its fuel or spark problem that's causing it.
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, March 11th, 2010 AT 5:38 PM
MEMITO66
Thank you for your answer but I'm afraid is a problem with the computer because with the old computer the car started and I changed the computer and dosen't want to start
Thursday, March 11th, 2010 AT 5:46 PM
