1998 Plymouth Voyager
SUDOKUFAN77
  • 1998 PLYMOUTH VOYAGER
Electrical problem
The main problem is that my car won't start from time to time. I have had it checked and it's not the starter, battery, alternator, or transmission. The last time it was looked at they said I had several alarm codes on my car and that would explain what is happening. Could that be the problem and are there any other possible problems? If that is the problem is that an expensive job? Another small thing is from time to time my front speakers go out and I can't close my back windows, What is that about?
Thursday, August 27th, 2009 AT 1:40 PM
BMRFIXIT
  • 19,053 POSTS
If all tested and checked OK
then would suspect an BCM module at fault
and if so its few hundred $$$ job
as for the windows and radio try and wiggle the ignition key in place
if all work suspect bad ignition switch
that may be the cause for no start too
Sunday, August 30th, 2009 AT 7:27 AM
Related Engine Not Running Content
