1997 Plymouth Voyager Won't Start
JPW
  • 1997 PLYMOUTH VOYAGER
Engine Performance problem
1997 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
Hi! My 1997 Voyager just won't start. There is now spark
getting to the distributer. Rolling over but won't start. Can you tell me what it might be.
Monday, June 28th, 2010 AT 11:47 AM
Problem could be fuel or spark-both do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, June 28th, 2010 AT 12:00 PM
