1997 Plymouth Voyager the car will not restart
BRUCESDELL
  • 1997 PLYMOUTH VOYAGER
  • 6 CYL
  • 26,600 MILES
The car starts when cold & runs for 30 minutes, then it shuts off & will not restart. The starter just cranks but the car will not turn over.
Monday, July 26th, 2010 AT 9:19 PM
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, July 26th, 2010 AT 9:27 PM
