1996 Plymouth Voyager not running on all cylinders
COREYC
  • 1996 PLYMOUTH VOYAGER
  • 4 CYL
  • 110,000 MILES
I brought it to a friend of a friend and he scanned it for codes, he said it was only running on 2 cylinders and that it said ignition coil malfunction. I replaced the coil, the spark plugs and plug wires and still runs the same. Any other idea's out there? It does have a bad head gasket which I have replaced twice and am not interested in doing again, just watch oil level closely and fill as needed, as I have heard this engine is known to blow head gaskets.
Saturday, August 8th, 2009 AT 11:39 PM
You need to fix the headgasket could be it that's causing the misfiring. Due to coolant or oil fouling the plugs up
Sunday, August 9th, 2009 AT 1:03 AM
COREYC
There is oil in the coolant but no coolant in the oil, has been running great for 3 years with the blown head gasket, you still think that is it, and they charged me over $1000 to do it last time, dois that sound right?
Sunday, August 9th, 2009 AT 10:44 AM
