1996 Plymouth Voyager No start
POLOM
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 23,600 MILES
1996 Plymouth Voyager 3.0
Car was not successfully starting each time. Now it doesn't start at all
So I installed some new parts:
Starter
Neutral safety switch
Starter relay
Ignition switch
Still no start.
If I pull the starter relay, put the key in the RUN position and jumper sockets 87 and 30, the starter spins and the car starts.
I put on an ODB-II code reader and there are no codes showing.
What else should I try?
Thanks
Wednesday, January 28th, 2009 AT 12:06 AM
RACEFAN966
  • 5,029 POSTS
Ok first check resistance between term 85 and 86 on the relay itself should be 70 to 80 ohms anything else means you got a bad relay warranty it.
Now check term 85 and see if there is continues power to it it not then find short in wire and fix. Let me know what you find and we go from there.
Wednesday, January 28th, 2009 AT 10:46 AM
POLOM
  • 6 POSTS
Thanks racefan966
Starter relay:
Resistance across terminals 85 and 86 is 72 ohms, so it's ok.
PDC cavity for starter relay:
Cavity 30 connected to ground shows 12.5 volts - ok.
Cavity 87 to starter solenoid shows continuity - ok
Cavity 86 shows no voltage to ground with key in START position - not ok.
Cavity 85 shows no continuity to ground - no ok.
Park/Neutral switch:
Center pin to transaxle shows continuity in Park and Neutral, no contuity in Reverse and D - ok
So it looks like short or open to terminals 86 and 85.
Any suggestions on how to track that down?
Thanks.
Friday, January 30th, 2009 AT 11:03 AM
RACEFAN966
  • 5,029 POSTS
Ok first off when you said you replaced the ignition switch which part did you replace the key and tumbler or the electical part? Let me know and we will go from there.
Friday, January 30th, 2009 AT 10:55 PM
POLOM
  • 6 POSTS
I replaced the electrical ignition switch on the steering column, not the lock cylinder.
Saturday, January 31st, 2009 AT 1:51 AM
RACEFAN966
  • 5,029 POSTS
Well it sound like the neutral saftey switch may be bad. As for the power to term 86 that comes from the ignition switch. It comes from the switch with a yellow wire to a 3 amp fuse (#10) in the fuse box and then goes to a yellow/red wire. Then there is a 9 amp fuse that is the run fuse and it goes to the relay via a white/black wire to the power module and then comes out of that tan and to the relay. So check the fuses to make sure none are blown and go from there.
Saturday, January 31st, 2009 AT 9:03 AM
POLOM
  • 6 POSTS
Okay, found the problem.
I started following the yellow wire from the ignition switch and the first thing I came across was a relay from an aftermarket alarm system which had been spliced into the wire. One of the connectors had fallen out of the relay.
Thanks a lot for your help racefan966.
Saturday, January 31st, 2009 AT 11:58 AM
RACEFAN966
  • 5,029 POSTS
Great I am glad that the work paid off. It is great when you find the problem and was able to do it yourself. Thanks for the update if there is anything else just ask.
Monday, February 2nd, 2009 AT 12:42 PM
