1996 Plymouth Voyager dies and will not start till it sets
JASON99991973
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 120,000 MILES
It will die when diving and will not start for 10 or 15 mins when it died I pulled the coil wire to see if it had spark and it did not it is like it cools off and it will start then it goes for a few miles and the same thing it is not a fuel prob it is just loseing spark it just dies I have replaced the dist. And coil and it did not fix it can you please help me thankyou
Friday, February 19th, 2010 AT 11:08 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coils resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Saturday, February 20th, 2010 AT 4:09 AM
CARADIODOC
  • 34,396 POSTS
Also, you must check if the fuel pump is running during engine cranking. Since you have a distributor, I'm guessing you have the 3.0L engine. To start troubleshooting, measure the voltage on the 12 volt power wire to the ignition coil, fuel injectors, or the small wires on the back of the alternator. You should find battery voltage on all of those points for only one to two seconds after turning on the ignition switch. It will go back to 0 volts and stay there until the engine is rotating, (cranking or running).
If voltage is there for those first couple of seconds, the circuit is working properly. If the voltage doesn't reappear during cranking, you need to troubleshoot the trigger circuit which includes the pickup assembly in the distributor. If the voltage does not appear for the first two seconds after the ignition switch is turned on, there is a problem with the Automatic Shutdown (ASD) relay or its circuitry.
Caradiodoc
Sunday, February 21st, 2010 AT 7:36 AM
