1996 Plymouth Voyager 96 Ply Grand Voyager died while drivi
MELODYJEAN70
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 90,000 MILES
Van died while driving. No sounds, no engine lights. Had been having trouble starting it. Replaced starter and crankshaft sensor. Car tries to start (turns over) but won't fire up. Sounds like it's not getting fuel, but fuel pressure is 40. Mechanic is puzzled. It's also had trouble going into drive occasionally and sometimes slips out of drive right after starting but will go back into gear after a minute of shifting it back and forth. Please help! Mom w/ 2 babies and no car is miserable! 90k miles, automatic
Sunday, April 13th, 2008 AT 2:27 AM
MERLIN2021
  • 17,250 POSTS
Pressur with key on engine off should be 49 psi, yours indicates either a weak pump, or clogged filter, you can test the pressre at the tank just before the filter to eliminate the guesswork.
Sunday, April 13th, 2008 AT 6:28 AM
