1996 Plymouth Voyager
ALIA85
  • 1996 PLYMOUTH VOYAGER
Our Plymouth Voyagers oil looks milky and were wondering if could be the head gasket?
Wednesday, January 6th, 2010 AT 5:01 PM
CARADIODOC
  • 33,922 POSTS
If you're seeing white crud under the oil fill cap, that's usually from condensation due to excessive short trip driving that doesn't allow the engine to reach normal operating temperature. That is one of the most damaging things you can do to an engine. At least once a week, get it warmed up and on the highway for a dozen miles. If it's bad enough, you will even see water droplets fall off if you shake the cap.
Coolant in the oil from a leaking head gasket turns the oil a sludgy light brown if it's bad enough. Antifreeze will melt the thin first layer of metal on engine bearings. You didn't list your engine size. The V-6 engines don't have very much head gasket trouble. Head gaskets problems are more common in the four cylinder engines.
Caradiodoc
Friday, January 8th, 2010 AT 4:12 AM
