lots of smoke
PLYMOUTH VOYAGER
DDUBOIS55
  • 5 POSTS
88 voyager van smokes at slow speeds, when idling and backing. ive been told its probably the valve stems, but that if i get a valve job, the increased compression would cause other parts such as the pistons to wear out faster. t or f? if true, should i not worry about the smoke and drive it till it dies?
Jun 9, 2006 at 10:56 AM
SYNCRAIT
  • 235 POSTS
whats it got for miles..... the way i usually figure it is a quart of oil is sometimes cheaper than an overhaul if you dont expect the car to last more than another year
Jun 9, 2006 at 11:39 PM
DDUBOIS55
  • 5 POSTS
its got about 131000 miles. seems like it should have some more miles in it b4 i put it out 2 pasture.
Jun 10, 2006 at 1:49 PM
