2001 Plymouth Voyager I need a hot wire under the hood
2001 PLYMOUTH VOYAGER
ROY08
Electrical problem
2001 Plymouth Voyager 6 cyl Front Wheel Drive Automatic
I am installing an electrical device under the hood that needs a wire that is hot only when the car is on. The circuit will be fused with a 20 amp fuse. Most of my car wiring is cabled and tied up with lots of electrical tape. I really would appreciate your help.
Jun 13, 2008 at 10:49 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:09a9b55027="roy08"]Electrical problem
I am installing an electrical device under the hood that needs a wire that is hot only when the car is on. The circuit will be fused with a 20 amp fuse. Most of my car wiring is cabled and tied up with lots of electrical tape. I really would appreciate your help.[/quote:09a9b55027]
I would find a 30 amp or higher in the underhood Power Distribution Block to tie into. You will probably have to undo some of the taping to get to the wires.
Using a test light probe each fuse, first with key in off position then with key on.
Jun 17, 2008 at 1:33 AM
