1992 Plymouth Voyager fuel pump wiring
1992 PLYMOUTH VOYAGER
20,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOYFULJOE
  • 14 POSTS
What are the wires on the fuel pump harness . I have been having issues with no fuel pressure. I changed pump and filter ran well for 2 weeks. Then same issue. I want to run 12 volts direct to pump and see if new pump is bad
Jun 18, 2010 at 10:05 AM
Hi joyfuljoe, Welcome to 2carpros and TY for the donation
Power the dark green and black wire on the fuel pump connector by teeing in, comes on test the fuel pump relay and the ASD relay-don't come on-test the ground circuit
Jun 18, 2010 at 10:29 AM
