1996 Plymouth Voyager serpentine belt
JULIERB
  • 1996 PLYMOUTH VOYAGER
Noises problem
1996 Plymouth Voyager 6 cyl 143000 miles
HELP! How do I get the serpentine belt back on after slipping off while spraying Belt Dressing?
Thank you!
Monday, November 17th, 2008 AT 2:58 PM
LEGITIMATE007
  • 5,121 POSTS
You need to get a serpentine belt tool or a wratchet with the correct bolt size where you can turn/bend the tensioner so that you can but the belt back on
Monday, November 17th, 2008 AT 3:29 PM
LEGITIMATE007
  • 5,121 POSTS
Sorry, there is a pulley called a belt tensioner that keeps the tension on the belt so that it doesnt fall off, all you have to do is put a socket wrench on it and force it foward so that the tension is released.
Monday, November 17th, 2008 AT 3:31 PM
