1997 Plymouth Neon Car won't start
NAMELESS
  • 1997 PLYMOUTH NEON
  • 4 CYL
  • FWD
  • 210,344 MILES
Ok my problem is my car was broke into and now my car won't start! Not sure if I need a new battery or what! But the engine turns but the car is not starting? The car inside lights comes on as well but the car is just not starting?
Monday, November 30th, 2009 AT 10:31 AM
JDL
  • 16,098 POSTS
Welcome to the forum, have a helper crank it, while you check for spark at the plugs, if you have spark everywhere, use a gage and check fuel pressure.
Does the check engine come on when you first turn the key on? Can you communicate with computer? You should be able to get some mil codes. You cycle the key just till the dash lites come on, no further. On--off, on--off, on, then the check engine lite starts flashing, you count the flashes to get the codes. Your looking for two digit codes, a code 24 is 2 quick flashes, a pause, 4 quick flashes.
Monday, November 30th, 2009 AT 2:50 PM
NAMELESS
I would need it to go to the shop the check engine light has always been on since I replaced the engine the shop never reset the setting to the engine! But the car cranks it just won't start! Someone was saying that the person that broke into my car could of shorted out the starter since they could not steal anything
Monday, November 30th, 2009 AT 5:02 PM
JDL
  • 16,098 POSTS
If the vehicle cranks good, the problem isn't the starter.
Tuesday, December 1st, 2009 AT 8:58 AM
