1997 Plymouth Neon wont start
16,000 MILES • 4 CYL • FWD • AUTOMATIC
ZOMBIESLAYER45
car kept staling so I replaced camshaft sensor and o2 censor car ran fine now it want start turns over but wont start
Jun 13, 2010 at 4:04 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 13, 2010 at 5:50 PM
