1988 Plymouth Horizon Head Gasket
FROGGYOKC
I have a 88 horizon 4cyl with 160k miles on it. I am pretty sure I need a new head gasket. I am a widow with the usual tools and have done some simple car repairs water pump, starter ect. and have helped with many more. I have contacted mechanics and they are not wanting to do this repair. Is this a repair I can do with a good manual? Thanks
Apr 20, 2007 at 6:29 AM
  • 110,251 POSTS
Hi:
It sounds like you've gotten your hands dirty in the past, so with a good manual and some determination, I think you could do it. However, when the head is off, I recommend you have it checked for warping.
If you run into trouble, let me know and I'll try to help.
Oct 22, 2008 at 12:32 PM
Suggested Repair
A careful DIYer can replace the head gasket with a good manual and determination. When the cylinder head is off, have it checked for warpage before reassembly.
Conversation Summary
The owner of a 1988 Plymouth Horizon with 160,000 miles believes the head gasket needs replacement and asks whether the job is possible with a good manual. The expert says it can be done with determination and recommends having the head checked for warping while it is off.
