1999 Plymouth Breeze Air Bag Light
1999 PLYMOUTH BREEZE
169,000 MILES • 4 CYL • FWD • AUTOMATIC
CBOURKE
My air bag light recently came on. I checked the fuse panel and found a blown fuse. What could have caused this? I had the battery unhooked for some time then I hooked it back up. Could that have caused a surge? Also, if I replace the fuse, will the air bag blow up in my face?
Nov 5, 2008 at 4:09 AM
2CARPRO JACK
  • 11,533 POSTS
Unhooking the battery wont cause a fuse to blow.Something in the system must have shorted to cause the fuse to pop. No, replacing the fuse wont cause the bag to go off.I do suggest having the system scanned ASAP to get it working again and see why the fuse popped
Nov 5, 2008 at 11:57 PM
CBOURKE
[quote:63cd5fab35="2CarPro Jack"]Unhooking the battery wont cause a fuse to blow.Something in the system must have shorted to cause the fuse to pop. No, replacing the fuse wont cause the bag to go off.I do suggest having the system scanned ASAP to get it working again and see why the fuse popped[/quote:63cd5fab35]
how do i go about scanning the system?
thanks for the reply
Nov 6, 2008 at 12:05 AM
2CARPRO JACK
  • 11,533 POSTS
Requires a scan tool that is capable of doing the SRS systems
Nov 6, 2008 at 1:24 AM
