1999 Plymouth Breeze brake light on dash does not go out
1999 PLYMOUTH BREEZE
112,000 MILES • 4 CYL • FWD • AUTOMATIC
BRADM2
  • 5 POSTS
I just purchased a 99 plymouth breeze fot my daughter. While driving it the left rear wheel cylinder went bad. Well actually the shoes were completely gone and the cylinder came apart. I replaced the wheel cylinder and shoes on both sides. Bled the brakes and verified the brakes worked, but, my dash brake light is still on. DId I miss something? How do I get it back off?
May 2, 2010 at 7:04 AM
CARADIODOC
  • 34,381 POSTS
Hi bradm2. Welcome to the forum. First, verify the cause of the light being on. Unplug the low fluid switch on the master cylinder reservoir. If the light goes out, fill the fluid or the switch is stuck. Next, unplug the pressure differential valve below the master cylinder. Chrysler's pressure differential valve is spring-loaded but sometimes they get stuck. A good jab on the pedal often releases it. You might also, in rare instances, need to crack open one line on the master cylinder, then have a helper slowly push the pedal until the light goes out, then quickly tighten the line before the pedal is released. A stretched or rusted / sticking parking brake cable can prevent the brake from completely releasing and will also turn the light on. A clue here is the light will get just a little brighter when you apply the parking brake. It will be barely noticeable, but if you see a tiny change in brightness when you apply the parking brake, it isn't the cause of the light being on.
caradiodoc
May 2, 2010 at 7:27 AM
BRADM2
  • 5 POSTS
Thanks for the information. I was able to find the problem. I had filled the resevoir a couple times while bleeding all 4 corners, but, when I looked at the resevoir after doing the bleed it didn't look like it was low. It was low however. Refilled resevoir ad now everything is great. Thanks again.
May 2, 2010 at 1:31 PM
CARADIODOC
  • 34,381 POSTS
Happy I could help. As a side note, don't top off the fluid periodically. After a brake job or repair is completed and the fluid is filled, it will only go down if there is a leak or if the pads have worn down. We used to have to rebuild calipers at just about every brake job, but today they give so little trouble, we just push the pistons back in to make room for the new pads. Doing so forces all that fluid behind the pistons back up into the reservoir. You won't HURT anything by previously filling the reservoir, but that overflowing fluid will make a miserable mess on the painted surfaces and on the floor.
Come back and see me when you have another problem.
caradiodoc
May 2, 2010 at 2:58 PM
