Welcome, if it cranks good but won't start, have a helper crank it, while you check for spark at the plugs. If no spark, check the primary circuits at the coil and injectors, engine cranking. The dark green wire with orange tracer should be hot, engine cranking. That voltage comes from the asd relay, that doesn't mean the relay is faulty, you need to check the circuits at the relay. Because the crank and cam sensors may share some circuits, I check them both.
SPONSORED LINKS
Monday, October 5th, 2009 AT 11:16 AM
