1996 Plymouth Breeze want start
DESHAN20
  • 1996 PLYMOUTH BREEZE
Engine Mechanical problem
1996 Plymouth Breeze 4 cyl Automatic
i tried to start my car today but it never cranked over. It just kept clicking like it was but never did. What is the cause of this problem?
Monday, March 29th, 2010 AT 4:03 PM
Did you have a check engine light come on or has flashed prior to this problem and when was your last tune-up?
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, March 29th, 2010 AT 4:30 PM
