Car ran good with no smoke but cut out after 10-15 minutes, then cut out and will not run except very rough off two cylinders, 2 and 3. Replaced coil, crank sensor, cam sensor, battery, plugs, wires... Checked compression, about 185-210,,, Cam turns as it will run briefly with two cylinders. Fans operate direct off battery but not off conector and all fuses good. The only thing I see left is pcm. could there be another reason other than this???? thank you!
Jul 30, 2009 at 6:57 AM
