1998 Plymouth Breeze no spark after changing ex manifold
CSPRINGER826
  • 1998 PLYMOUTH BREEZE
  • 4 CYL
  • FWD
  • 142,000 MILES
Well I had to change the ex manifold in my car so I went a got when and started the car up ran fine drove it on my ramps changed the manifold no there is no spark I have changed the coil, cranksensor un pluged the cam sensor still no spark checked all my fuses all my wires connections just cant figure it out now I have noticed that with the ingniton swith on the on position you can take the key out now I am woundering if that would cause it seeing I have just bought the car I dont no if the guy had riged the key up to work I am not sure?Please help me thanls
Saturday, May 31st, 2008 AT 5:44 PM
2CARPRO JACK
  • 11,533 POSTS
Does it have spark? Fuel pressure? Need to see what is missing here. If has both get a noid light and check for injector pulse. If not, use test light to see if there is power at the coil
Monday, June 2nd, 2008 AT 7:55 AM
