Codes P2757 and P2757
NASER NASER
  • 836 POSTS
I see but it doesn't say when I should do that. When filling it cold until it comes out of overflow plug, push the pin in and start the car, let it get warm, then add more? If I do that I wouldn't be able to know what temperature is the fluid at since I use the scanner and I assume the pin am gonna push has to do with telling me what temperature it is? Can you confirm from somewhere that it is a 130f before I open it up and add more? I drained twice now, black, without pushing the pin and it has gotten somewhat worse feels like it's low on fluid. So not sure when I should push the pin in and when I should release it.
Wednesday, May 6th, 2020 AT 5:26 PM
  • 52,797 POSTS
I would push the pin in when you are filling it.
That is allowing the air to leave so fluid can enter the system.
If you have air, it will feel that way as the fluid is low.
As far as the temperature, I was looking and it opens at 120.
Wednesday, May 6th, 2020 AT 5:40 PM
