• HOME
  • ASK A QUESTION
  • REPAIR GUIDES
  • BECOME A MEMBER
  • LOG IN
    Login with Facebook
    OR
    NOT A MEMBER?FORGOT PASSWORD?
  • CONTACT US
  • PRIVACY POLICY
  • TERMS AND CONDITIONS
  • Home
  • Hyundai
  • Santa Fe
  • Drivetrain
  • Transmission
  • Computer TCM
  • Location
Code P0732, second gear incorrect ratio, where is the transmission module located?
  • PREV
  • 1
  • 2
  • NEXT
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,325 POSTS
Yep here is the info,
Non-SCC (Smart Cruise Control): ECU part number 211012GK02QQH
SCC-equipped: ECU part number 211012GK02QQH
Saturday, February 15th, 2025 AT 9:50 AM
  • PREV
  • 1
  • 2
  • NEXT
Related Transmission Computer TCM Location Content
Transmission Control Module
I Am Getting Codes P0890 And P0501. Was Told To Replace Tcm But Not Sure Where It Is Located.
Asked by tjohnson126 ·
6 IMAGES
2007
HYUNDAI SANTA FE
2001 Hyundai Santa Fe No Drive Gears
Was Driving On The Highway When I Lost Drive. Went Into Neutral. No Clunk No Grind. Nothing. Codes Say There Is An Open/short In The Under...
Asked by paunchy225 ·
1 ANSWER
2001
HYUNDAI SANTA FE
Transmission Removal?
I Have A Slow Leak Coming From The Transaxle Case Just Behind The Motor. I Checked The Fluid Level With The Dip Stick Per The Owners Manual...
Asked by KevinQ ·
1 ANSWER
14 IMAGES
2003
HYUNDAI SANTA FE
Won't Go Into Drive Or Reverse
It Wont Go Into Drive Or Reverse. The Gear Position Lever Moves From Gear To Gear But No Movement. This Happened Before And The Car Jerked...
Asked by tonymccombs ·
1 IMAGE
2002
HYUNDAI SANTA FE
Trans-axle Range Switch Wiring
Hello, I Want To Know Wiring. Trans-axle Range Switch With Mention Colors.
Asked by Muhannad Arab ·
1 ANSWER
1 IMAGE
2001
HYUNDAI SANTA FE
VIEW MORE
Check Engine Light
Check Engine Light
Code Read Retrieval/Clear Chevrolet
Code Read Retrieval/Clear Mercedes Benz
  • Contact
  • Help
  • About
  • Privacy Policy
  • Terms & Conditions
© 1999 - 2025 2CarPros, Inc.
