Engine is overheating after twenty minutes of running?
DARTHIS
  • FORD RANGER
Ranger v6 overheats sitting still
Wednesday, October 28th, 2020 AT 2:21 PM (Merged)
BHUGG
  • 157 POSTS
Check for the proper level of antifreeze. Don't use just water.
Does the cooling fan work?
If the antifreeze is good, replace the thremostat.
BHUGG
  • 157 POSTS
If you get answers to your question, let us know, we thrive on feedback.
SIRGIBBY
  • 32 POSTS
Water pump. Belts tight?
HMTYSON1
  • FORD RANGER
It overheated recently, and I had the thermostat replaced. That seemed to fix the problem, until I was driving up a steep hill in San Diego. I did have the A/C on. When the gauge went up, from the normal position it shot up to the redline, I pulled over and turned the A/C off and switched the heater, and the gauge fell immediately. Is there anything else that could cause the overheating. I did drive around for about two hours after the incident, up and down all over downtown without problem.
SERVICE WRITER
  • 9,123 POSTS
When a problem is intermittant, those are the tough ones. It may be a faulty replacement thermostat, may be that the fan is not coming on. There is a wide variety of possibilities. You'll need to watch it or try to reproduce it.
CFARMER1
  • 1992 FORD RANGER
  • 6 CYL
  • MANUAL
  • 81,000 MILES
My ranger will overheat after about 20 mins of running. Coolant will just start pouring out of the overflow. I replaced the water pump themostat the hose to the thermostat and there is no water in the oil
Wednesday, October 28th, 2020 AT 2:22 PM (Merged)
Could be a problem with the fan clutch, radiator/cap to include air in the system if it continues get it block and pressure tested
CFARMER1
I put a new cap on today and it still did it afterwards and the fan is working just fine
If there's no air in it -final step is to get it block and pressure tested to find out if it has blown headgasket, cracked head and block to include an intake manifold leak
