Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Engine
Symptoms
Not Running
Truck will not start
1992 FORD RANGER
10,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
CYNTHIA MORGAN
MEMBER
1 POST
Looking at the engine there is spark from the four plugs on the left side, no spark from the four on the right side.
May 10, 2017 at 10:47 AM
STEVE W.
Experienced Mechanic
More than likely a bad coil pack if all four are bad. Both packs are the same so you could just swap them and see if the problem follows the pack.
May 10, 2017 at 11:16 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
