Engine is Overheating?
170,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
LISA KENNEDY
My engine is overheating, can you please tell me why?
Mar 22, 2023 at 7:09 AM
  • 110,248 POSTS
If the engine is overheating, it could be the result of a few different things. For example, it could be a faulty coolant thermostat, the coolant could be low, the cooling fans are not working, or even a faulty head gasket.
I have some questions to try and narrow things down. First, did you check to make sure the engine coolant is full? If so, how long does it take to overheat? Next, does it overheat at highway speeds or only in stop and go traffic? Also, have you checked for leaks and have you noticed any white smoke from the exhaust? Do you notice if the radiator cooling fans are running?
Let me know. In the interim, here is a link that explains how the cooling system works in detail:
https://www.2carpros.com/articles/engine-cooling-system
Let me know as much as you can.
Mar 22, 2023 at 12:45 PM
