On board diagnostics
1996 CADILLAC DEVILLE CONCOURS
163,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
HALLNASS
Going to work and unlike previously. Go to get In as usual, and key fob did not work.had to use key (unheard of). Windows, ext lights, radio, and some gauges were dead. Interior dash including radio and dead gauges were lit but that was all. Says might not restart on panel. But, started and ran as usual despite the malfunction. Tried the built in diagnostic and it read there was no data for any of it. PCM, ECM, etc. Any suggestions?
Sep 17, 2019 at 12:41 AM
Good morning,
I would start by having the battery tested. It sounds like you have low voltage causing the issue.
I would also check the charging system as well to be sure it is maintaining the battery charge.
Sep 17, 2019 at 1:54 AM
HALLNASS
Thank you. I will be trying that today. Appreciate your time.
Sep 17, 2019 at 2:11 AM
You are welcome.
Always glad to help.
Keep us updated.
Sep 17, 2019 at 2:15 AM
