I have a 1996 4.0L Aurora with about 72k miles. This evening the message center read turn off a/c, followed quickly by engine is hot, followed by too hot-turn off. Fortunately I was only a couple blocks from home, and I made it back.
When I checked the engine, I found the belt, on the drivers side, front upper end of the even bank, to be totally shredded. I assume this is the water pump belt. I was told that I should replace both the water pump belt, and the a/c belt together, since they usually last about the same time. Plus the section will be exposed to replace them.
What is the procedure to replace both the water pump belt, and the a/c belt? Thank you.
Oct 5, 2007 at 4:49 PM
