1999 Other Oldsmobile Models cranking assembly, drive belt u
1999 OLDSMOBILE
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROCKET5043
my suilouette van starts but the motor isn't turning, my belt assymly isn't spinning, It looks like one of the pulleys is broke. how do I get in there and take out this particular part and is there a web site to go to that shows me a description of my engine?
Feb 24, 2008 at 7:14 AM
MASTERTECHTIM
  • 4,750 POSTS
did the pulley on the bottom center of engine break? or is it one of the smaller ones? is it heavy?
Feb 24, 2008 at 7:37 AM
2CARPRO JACK
  • 11,533 POSTS
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
All the info you need for your car, online manual.
Feb 25, 2008 at 12:06 AM
ROCKET5043
It's a smaller pulley towards the back of the engine on the side. It one belt that runs the whole engine.
What is that part called and can it get removed and replaced and how do you get it out?
Feb 25, 2008 at 12:46 PM
MASTERTECHTIM
  • 4,750 POSTS
well your talking about the serpentine belt and it also sounds like a idler pulley went bad. usually the idler puller is only held in by a single bolt in the center of the pulley and are very inexpensive. my best advise is to get a on line service manual for step by step instructions. or under the hood on the engine or radiator support is where the belt routing diagram usually is.
Feb 25, 2008 at 10:07 PM
