1994 oldsmobile 88 royale
1994 OLDSMOBILE
BRISAL
the car has a v-6 engine with 85,000 miles.the serpentine belt is broken and needs replaced and the alternator has burned up.our question is:
what is involved in replacing the serpentine belt and alternator ?? Is this a major repair or could a person with limited mechanical ability perform the repair ??
thank you for your response to our question.
Brian & Sally Soby
Jul 21, 2007 at 2:28 PM
ROCKWOOD84
  • 103 POSTS
yes just take your time and remember what goes where.if you want to go get a manual at a parts store and it will walk you through the process step by step. the should be a diagram on the hood or some place under the hood than shows the way the belt goes back on.good luck
Jul 29, 2007 at 8:14 PM
