Oldsmobile Achieva No Crank After Overheat
Suggested Repair
Check the battery cable connections for corrosion. Grasp each cable and rotate it about a quarter to a half turn to see if a poor connection is causing the no-crank condition. Once the car starts reliably, diagnose the overheating separately.
Conversation Summary
An Oldsmobile Achieva LS began running hot in a drive-through. After it was shut off, the dash lights came on but the engine would not crank. It later started after the shifter was confirmed in park, then made a grinding over-crank noise when the key was released, and the airbag light stayed on. A later restart attempt again produced only lights and no cranking. The expert recommended first checking and slightly rotating the battery cables in case the connections are corroded, then addressing the overheating once it runs.
