engine light, trac off antilock light all on
OLDSMOBILE
OLZALERO
i have a 2001 oldsmobile alero ,with 61000 miles and the 4 cylinder engine.my problem is i was driving my car and all at once the engine light, the antilock brake,light and the traction off light all came on at once .the brake wasnt even being used at the time.they just came on.the brakes work fine.i work
in the business and come across alot of other oldsmobile cars and alot have the sam three lights on.
what is the problem?
Jun 15, 2006 at 10:07 AM
ROXEECO
i had the same problem. all the lights were on. after about 5 months of driving it like that my bearings had to be replaced. after that the lights turned off. the part itself ran about $90. you cant by the bearing seperated. what you need is a hub assembly. hope this helps.
Aug 20, 2006 at 3:28 PM
