1997 Oldsmobile Achieva Stuck in Park
OLDSMOBILE
TYRA2703
I have an olds achieva 1997 and my break light and abs light will not go off and i cannot take the car out of park what should I do
Mar 9, 2007 at 11:11 AM
CHEVY22
  • 1,375 POSTS
do you still have brake lights?? or are the out also
Mar 10, 2007 at 12:09 AM
TYRA2703
I do still have break lights
Mar 10, 2007 at 2:11 AM
CHEVY22
  • 1,375 POSTS
ok this sounds like a shift interlock cable problem
Mar 10, 2007 at 2:13 AM
TYRA2703
ok so how would i fix that and thank you for taking the time to tell me this
Mar 10, 2007 at 3:22 AM
CHEVY22
  • 1,375 POSTS
it is a cable that runs from your shifter to the brake pedal , you should have a small slot on the shifter base that you can fit a key type object into , if so try that and see if the shifter moves atleast this will get you going for now
Mar 10, 2007 at 3:28 AM
Suggested Repair
The symptoms point to a shift interlock cable running from the shifter to the brake pedal. Use the small override slot on the shifter base with a key-type object to release the shifter temporarily so the car can be moved, then inspect and repair the interlock cable.
Conversation Summary
The owner of a 1997 Oldsmobile Achieva said the brake and ABS lights stay on and the car will not shift out of Park, although the brake lights still work. The expert identified a likely shift interlock cable problem and described the temporary override slot on the shifter base.
