1992 Oldsmobile Achieva Turn Signals Stay On
GMC
WILSON5R
  • 8 POSTS
the turn signals on my 1992 oldsmobile achieva do not flash, they just stay on, but the four ways flash normally. how do i fix this?
Feb 14, 2006 at 4:55 AM
MVANNESSJR
  • 223 POSTS
Replace the turn signal flasher.
Feb 15, 2006 at 12:34 AM
WILSON5R
  • 8 POSTS
where can i find the flasher?
Feb 15, 2006 at 3:34 AM
FISHERMAN
  • 937 POSTS
under the dashboard sometimes on the same fuse board, there will be two flasers one for the "hazard" and the other for turn signals, simply turn the hazard on and "hear" the "clicking sound" there will be the two of them.
Feb 15, 2006 at 4:20 AM
Suggested Repair
Replace the turn signal flasher. It is usually under the dashboard on the fuse board, separate from the hazard flasher. Turn the hazards on and listen for the clicking to tell the two flashers apart.
Conversation Summary
The owner of a 1992 Oldsmobile Achieva reported that the turn signals stay on instead of flashing, while the hazard lights flash normally. Experts advised replacing the turn signal flasher and said it is typically under the dashboard on the fuse board, next to a separate hazard flasher that can be located by the clicking sound when the hazards are on.
