1996 Oldsmobile Cutlass Supreme Misfire
Suggested Repair
Perform a compression test and a cooling-system pressure test. The confirmed failure was a cracked cylinder head between the valves on cylinder 1, with plugged cooling passages. Repair or replace the cracked head, then thoroughly flush the cooling system.
Conversation Summary
A 1996 Oldsmobile Cutlass Supreme with a 3.1L engine ran rough with the check engine light on. A scan pointed to the coil or injector on cylinder 1, but the coil had spark, injector resistance was normal, and swapping injectors did not move the problem. Little fuel came from the removed plug, while white smoke and moisture appeared in the exhaust. The expert recommended compression and cooling-system pressure tests and a major coolant flush, noting that the computer may disable an injector on a non-firing cylinder. The owner later found the head cracked between the valves on cylinder 1 and the surrounding cooling passages plugged.
