1994 Cutlass Ciera No-Start Fuel Pump Fix
It's an Oldsmobile (sorry), Cutlass Ciera, 1994, 200,000 miles, 3.1l auto trans.
Suggested Repair
With the key on and engine off, check the fuel pump power and ground against the wiring diagram. If both are good, the pump is the likely failure. Also inspect the tank sender ground because the gauge intermittently pegs full. If the pump can be heard running, measure fuel pressure at the filter; it should be about 40 psi, since a pump can run without pumping.
Conversation Summary
A 1994 Oldsmobile Cutlass Ciera with a 3.1L engine cranks but will not start, and the fuel pump does not prime with the key on. The fuel gauge had intermittently pegged at full, and the owner could not locate the fuel pump fuse or a damaged harness wire. Advice was to verify pump power and ground; good power and ground point to a failed pump. An erratic gauge can indicate a loose ground, and on these Oldsmobiles pump failure often follows gauge problems. If the pump runs, fuel pressure should be checked at the filter for about 40 psi because the pump may run without pumping.
