1990 Oldsmobile Cutlass Ciera No Fuel
OLDSMOBILE
LSH1984
Oldsmobile Cutlass Ciera 1990; 125834 miles, 3.3L V-6
I have been having a problem with the fuel pump on this car. I changed the pump about a year ago....the car will fire and start in park...but then sputter and die. I have checked to see if the pumo is running when the key is turned and it doesn't. My question is....do i change the pump again or is it something more. had friend look at it. He thought it might be a relay but it wasn't. I origanally got it running by banging on the tank while the key is in the on position. She ran for over a week after that. Now i am back to a quarter tank and no fuel delivery. I need to know that i am not missing something here. Anyone with input is welcome to answer.
May 2, 2007 at 7:57 AM
  • 75,988 POSTS
[quote:84e2b8f3d8="LSH1984"]Oldsmobile Cutlass Ciera 1990; 125834 miles, 3.3L V-6
I have been having a problem with the fuel pump on this car. I changed the pump about a year ago....the car will fire and start in park...but then sputter and die. I have checked to see if the pumo is running when the key is turned and it doesn't. My question is....do i change the pump again or is it something more. had friend look at it. He thought it might be a relay but it wasn't. I origanally got it running by banging on the tank while the key is in the on position. She ran for over a week after that. Now i am back to a quarter tank and no fuel delivery. I need to know that i am not missing something here. Anyone with input is welcome to answer.[/quote:84e2b8f3d8]
>I origanally got it running by banging on the tank while the key is in the on position. She ran for over a week after that<
If you have to bang it to bring it back alive-the problem is within the pump-recheck.
May 2, 2007 at 6:40 PM
Suggested Repair
Recheck the fuel pump. Temporarily restoring operation by tapping the tank indicates the fault is inside the pump rather than the relay.
Conversation Summary
The owner of a 1990 Oldsmobile Cutlass Ciera reports no fuel delivery: the engine starts in park, then sputters and dies, and the fuel pump does not run when the key is turned on. A friend ruled out the relay, and tapping the tank briefly restored operation for about a week. The expert says that needing to tap the tank points to a problem within the fuel pump and recommends rechecking it.
